Hi Air
Back with submenu issues...
I can live with having to use icons for the submenu dropdown but unfortunately on mobile view the icon is not next the the Manu name but all the way on the right side causing the user to oversee the icon and thus the submenu (see screenshot) .. is there a way to have the icon next to the text as in the desktop version?
Thanks, Pascal
Don't you want to make whole menu link opening submenu as I have explained in your last topic?
But I'm open to any solution looking good a being user friendly
Thanks, Pascal
I mean this option https://rifetheme.com/help/docs/basic-setup/menus/menu-enhancements/#making-menu-item-not-clickable
But as we actually do have a page "show" it makes sense to keep it just using the arrow?
As for the "not clickable" I do not have any use for that
I think for now I'm happy if I can have the "arrow" for the submenu close to the submenu text in mobile view...
Thanks, Pascal
Thanks.. it close indeed. But since the menu is centered it now as shiftet to the left while also bringing the arrow closer... it would be nice if the menu text remeins centered (to align with those menus not having submenus) while the arrow come (even) closer
The link is here: https://zd.teamswitzerland.com
Screenshot shows what I mean .. hopefully
I thought it was impossible due to positioning way, but I have found a way :-)
Please use this custom CSS instead:
Thanks! You're the man!
I changed the code a little to suit my needs even better (the arrow was still too far way for me
Cheers, Pascal
Something changed? The code you gave to place the arrow closer to the submenus in mobile view are now tottally offset instead of being next to the menu item as on desktop.. how can I change this again? (see screenshot (desktop simulatiing mobile.. but same happens on the actual mobiles)
Thanks, Pascal
It seems you have disabled "submenu parents" being normal links.
Please try this custom CSS instead: With kind regards.
