Love this theme! First time using it and having a few roadblocks.
I am having trouble creating the layout of the Shop Page with the Customizer. There is a section at the top with 3 products in a vertical line that I cannot figure out how to turn off - it does not look very good (screenshot 1).
I would like the sections that are showing in screenshot 2 to be at the top of the page (Categories, then Products).
Also, can I edit the size of the product images anywhere? I am not seeing it in either Customizer or WooCommerce Settings...
Any help would be much appreciated.
Thank you.
Please also share a link, as I am not sure what is this element, and if it is even controlled by theme or Elementor.
Do you want to change the size of the whole brick, or literally size of the image?
You could either switch to smaller/bigger number of columns or select bigger/smaller layout size - images will adapt to it.
I would like to change the size of the entire brick if possible. I would like 4 brick columns and 3 rows maximum of products on the main shop page. I tried changing the columns/rows but it doesn't seem to be working, maybe I have something set up incorrectly.
Best,
It seems like something is set in not the best way. I would like to take a look inside.
1. Please tell me do you want to keep those products at the top that are placed vertically currently?
2. Could you please send me temporary* access to your WordPress so I could check there what is going on? Send it here on the forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
So those products at top you have added by editing Shop page.
So you can remove them by yourself.
As for columns and rows - currently you have set to display categories in front of the shop instead of products, but that is not the problem.
Currently, you have 5 categories, so that is why you don't see more.
However, I had to disable the plugin that was interfering: WooCommerce Product Archive Customiser
Instead, I have set everything in theme settings in Customizing → Shop(WooCommerce) settings → Products list → Bricks columns.
Hope that helps.
