Hello Air
I am creating a website using Rife Pro as usual and in need for submenus. As far as I see there is only one way to make submenus work? (using arrow (or other) icon on click to have the menu drop down?
One thing that I don't like is the "focus" border that happens on click (see screenshot).. how can that be removed?
And even better would be to have the menu dropdown on mouse over without having to use the icon and without having to click... is that possible?
Thanks a lot
Pascal
As for focus ring: https://rifetheme.com/help/docs/customizing-the-theme/header/main-menu/#accessibility-focus-rings-on-the-menu
Want to thank me with coffee?
Thanks for your fast and adequate support - as usual!
Sincerely, Pascal
Back to that annoying sub menu question. My client has now decided that he WANTS the submenu open on hover and not on click.. I tried to explain that this is a bad decision but he insists... I know that you don't offer that option but I'm stuck with this situation and the site is finished apart of this.. is there any way I can solve this issue?
Also the clients wants the submenus to be "open" as list already in the mobile view.. is that possible?
Sorry and thank you
Pascal
As for menu to be opened on hover - it would require fancy JavaScript modifications, to be as safe as possible, so I don't have any good news here.
AS for submenu to be open on mobile - I believe this custom CSS should do it: It is not perfect but should help.
Thanks for the info.. well, I guess the client will have to be forced to go with clicking to open the submenus on desktop!
Thanks for the css.. it works like a charm – same for the css for repoisitioning the arrow
Cheers, Pascal
