Hi Air
It's been a while but I have a question.
Using your theme Rife Pro with Elementor I have used another page (
https://saraas-horse-trek-mongolia.com/treks/) containing the "works" list as was meant to be. The consequence is the "work list" icon-link ((go back) in the bottom between the previous and next item selection )) doesn't work.. how can I assign my "personal link" (above) to this icon?
Thanks for your help!
Pascal
If you are not using the Works list page here, you can try to set proper page in Appearance → Customize → Works Settings → Works list → Works list main page.
Then it should be good :-) Let me konw if it works for you.
With kind reards.
Thanks!!
In my current project I have the same issue. So I did the above to solve the issue but unfortunately whatever page I assign in Works List Main Page always sends me to the archives page (https://nikatrade.dellamae.ch/work_genre/della-mae/) instead of the main page Kollektionen (https://nikatrade.dellamae.ch/kollektionen/)
I have changed the slug from "work" to "kollektion" .. maybe this is related to the issue?
Thanks, Pascal
Please check option Appearance → Customize → Works Settings → Single work → Navigate by categories → Disable.
Great! That solved the issue! Thans a lot!
