Hey guys! Hope you had a great holiday
Never like to bother unless I really can't figure something out but it is odd how I can't get a parallax Scroller album (such a great style you developed for Rife!) on the homepage and also show other elements like text, images etc. I can see that content in Elementor edit mode but not on view or preview. Screenshots attached and I can send login if that helps.
https://mel.photography/ Where do we edit the green button that says to scroll down?
I tried a secondary way of building the page and can see the other content but the parallax scroller effect isn't working and I can't get it to go full screen view
https://mel.photography/home/ And I think I asked about this before but it's not possible for the left right 5% image views to be black and white on mobile also? BIG THNKS and of course once any of these issues is resolved I never have to ask about again. BEST on into 2020!
If you want to have more then a scroller, then you have to go a different route:
1. Create a normal page and set it as a homepage.
2. Next, edit this page with Elementor, and add there our Scroller widget https://rifetheme.com/help/docs/content-management/elementor-widgets/
3. Now you can add other content where you want.
So this is more like your second attempt. If you want to get full width you will have to use full-width row for this. If you want full height, then mark Stretch the slider to the window height in Layout tab in widget settings while editing in Elementor.
If you want to edit color, please see this answer https://support.apollo13.eu/discussion/comment/21655/#Comment_21655
I recreated the page w Scroller widget but still can't get it to go full width, II used the widget Layout 'stretch' as suggested and the Row Section is set to Full Width and with no column padding and tried adding 100 to the % though I usually don't edit that element/area. Do the images have to be a certain proportion (they are are 1500px x 1000px as I usually format for full section slides) or what else can I do to make full width (the actual Album when viewed itself looks great).
And no idea why the background is black when I view https://mel.photography/home/ It's set to white in Section background options.
Does giving you the login help?
Sorry to bother you about this again, just hoping to finish and I'll know in the future how to not have these issues.
BEST to 2020!$
-Sterling
Is there a way to have the BW left/right slider preview or is that only when actual Album is viewed? https://mel.photography/album/fullscreen/
BIG UPS NEW YEARS EVE Fellas!!
It is not available on mobile becasue it is too heavy effect for mobile devices, and it would make them lag a lot.
