Hey Folks!
During March of 2020, and possibly April, answers may be delayed more than it usually happens. This is caused by my personal situation that requires a lot of time from me to be dedicated elsewhere, and also because of the local things that are happening currently cause of the all things connected to "Corona Virus".
Please be patient, all answers are coming as soon as possible, even if I have to stay late at night :-)
Sorry for any inconvenience.
Air.
'Next and Previous Post' image being stretched
Hi again!
On my single blog posts at the bottom the images that accompany the title are warped and stretched.
I've checked your documentation and the Blog page and also the custom Blog settings but can't see where I can correct this.
Please can you help? I'm sorry if it's really obvious...
The problem is here if you need to see it:
https://www.artoflifefilms.com/do-you-need-a-wedding-video/
Thanks - also is there a way of searching within the Rife category to see if this topic has been posted before? I can't find this option and when I search with Google it takes me outside of the forum.
Ta
Heather
    I suspect that some plugin is affecting this image, and instead of using the theme script that is resizing those images it inserts there full size image.
    I would need to debug it on your installation.
  • Hi again! Well you inspired me to contact my host supplier, Siteground first, as I could see they had automatically included a plugin and I wondered if it could be affecting it.
    My site originally started life as an http:// site and I upgraded the certificate to https:// a while ago. I didn't realise this might impact the images.
    They searched and updated the http image to work with https to ensure it works properly:
    set additional code in the .htaccess that looks like this, "Header always set Content-Security-Policy: upgrade-insecure-requests
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]"
    This appears to have fixed the warp effect on the images.
    The images are still a bit narrow for me, so was wondering where about I can adjust this if I need to? I can live with it as it is now though which is great!
    Thanks for replying and alerting me to being able to create fake admins - soooo useful for support!
    Best
    Heather
    Thanks for all the details - I wouldn't suspect that it is HTTPS related, but it is totally logical reason.
    hoodledoodles said: The images are still a bit narrow for me, so was wondering where about I can adjust this if I need to?
    In rife\advance\utilities\posts.php in lines ~262 & ~270 there are such calls:
    .'<span class="image">'.apollo13framework_make_post_image( $id, array( 245, 100 )).'</span>'
    If you would tweak part 245, 100 to your desired dimensions you will get a different result.
    I will think of a different solution, like adding this to theme options, or some less affecting code change.
