Sorry for confusing you, name of this setting should be different, cause now I see how it could be read. There is no way to change color of this background from panel but you can change it like described here: http://support.apollo13.eu/discussion/comment/2175#Comment_2175
Tks. I installed the plugin. Would you please give me the css to add in order to change in black the background of the following page? http://petrasedlaczek.com/category/blog/ Thank you !
What if I want to add an image as the background. Not just the color. What css code then? Everytime I try to add an image to the background the image only shows on the top bar above the blog bricks.....where the menu and logo reside. What I would like is for my white stripe at the top to stay white so the logo and menus are easy to read but the image only to display behind the blog bricks. How do I do that? Please note that this is the only page where I want this to happen. All other pages need to stay with a white background.
You could try to go to Pages, open your Blog page and set there background image. Then it should be only under blog. Please check if this is what you need.
Thank you !
Hypershot theme-> Appearance-> Color scheme
.I did :
body.archive article, body.search-no-results.search article, body.archive.category-empty article {
background-color: rgba(101,102,102,1);
... doesn't work.
What do u think?
Tks for your help !
Discussion closed.
Thank you !
