Hello aria! thanks for fixing my menu. I would like to change some options (for example change background color and opacity...cant' figure where to do that.
On mobile the old version of the hamburger is visible near to the new one :-S
i like how the overlay menu looks better than the normal menu in the hamburger version. is there a way to have the normal fixed menu and the responsive hamburger look like the overlay menu ....?
You have enabled to types of menu - normal and menu overlay. I believe you should disable menu-overlay https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/header/menu-overlay/
