How to remove the Youtube icons on an embed video
in FatMoon Posts: 3
Hi, i've been looking everywhere a solution to my problem. Whenever the page loads, the youtube UI appears on my home page slider, this makes the whole page looks hideous and unprofessional, please tell me you have a solution to fix this.
https://agstudios.nyc
Hadrien
    I don't see any YouTube icons on load or later. In which browser are you experiencing this?
    Hi, it appears on the 2 first seconds when i land on the HP on top and bottom of the video on google chrome.
    Thanks.
    I don't think there can be done anything about it. This is probably a limitation of how it can be done in Visual Composer when using YouTube.
    I will ask Daniel to take a look at your case., as he has more experience with it.
    Yes, you can't remove these YT things. You can try to use, for example, Revolution Slider and add mp4 video as a background. In this example: https://rifetheme.com/fatmoon-osaka , we used the YT video but you can use mp4 and won't see any YT logos.
    With regards,
    Lead Graphic Designer
    Duely noted ! Thanks Daniel.
