I am creating photo website for my Client. It will be in two languages.
In the future I will need woocommerce functionality.
My Cient select theme
https://rifetheme.com/photoproof-3/ with some modifications.
Ho can I add woocommerce functionality for this theme
https://rifetheme.com/photoproof-3/ maybe for selling some photos or services online?
Best,
Arek Ignasiak
You just need to install the woocommerce plugin and follow its steps. This plugin will generate needed pages and settings.
With regards,
Thank You for answer.
If I installl and configure woocommerce plugin, can I next add button with text Add to Cart on every picture for example on site/album like this https://rifetheme.com/photoproof-3/album/3-columns/ ?
Best,
Arek Ignasiak
You can link each photo in an album with product in the WooCommerce. If you will do that, it will add a button "Add to cart" on the photo in the album.
You can do it by option named Product this image represents in each photo options. Please check this https://rifetheme.com/help/docs/content-management/albums-works-post-types/album-media/
Thank You very much for help :-)
Kind regards,
Arek
