<div class="foot-left">© 2019 • K.SKRZYNECKA</div> <div class="foot-right"><a href="#">Created by Internet Space</a></div>
.foot-text{ display: flex; justify-content: space-between; max-width: 100%; float: none; }
@media only screen and (max-width: 600px) { .foot-text{ display: block; } }
.foot-left
.foot-right
<br />
I don't know if in the right corner, but you have for this footer text in Appearance → Customize → General settings → Footer → Content
There you can add HTML with link.
Later I can help you with positioning this text on the right, but I will need a live link.
I have add © 2019 • K.SKRZYNECKA in Appearance → Customize → General settings → Footer → Content but I need to add both informations: © 2019 • K.SKRZYNECKA on the left and Created by Internet Space with link to my site on the right/down corner.
Is it passible to put them both there similar like on attached file?
Site: https://skrzynecka5.js-metals.pl
Kind regards,
Arek
You would need to create such mini HTML structure as the footer content: and add such custom CSS: And you are done :-)
Thank you, on laptop/monitor it looks great :-)
but on smartphones text not fit, is too long
What shoud I change to make it looks on mobile similar like on attached file (one text under another) ?
Kind regards,
Arek
Please add such custom CSS:
Thank you very much, now it looks almost perfect
I have last question for this topic.
How can I decrease space between text @20119 • K.SKRZYNECKA and text Created by Internet Space because space is too big like on attached file?
Kind regards,
Arek
Please delete empty space between
.foot-left
and.foot-right
as it is converted to<br />
.With kind regards.
Now it looks perfect
Thank you very much for help.
Kind regards,
Arek
