Font Awesome Issue
in Rife Posts: 304
Hi Air
Hope all is good with you!
I have a small issue (see screenshot) with the arrows for rev/next post not showing... any suggestions?
Link: https://lunique-foundation.org/soupchill-basel-part-1/
    If you will switch to Font Awesome 5 in Elementor, you should be fine.
    To fix please try going to admin area → Elementor → Settings → Advanced → Load Font Awesome 4 Support → No.
    Please check if it will work for you, as your Elementor currently load font awesome 4 instead of 5. Maybe there will be some other setting for changing font awesome version, as once it is changed it disappers.
    Hey Air
    Thanks, that did the trick.. I know about that setting but I falsly assumed that it would load V4 in addition to V5... my bad!
    Thanks and have a great day
    Pascal
    I would assume the same. Maybe it is some quirk that it didn't work like that in this scenario.
    I am glad it is solved:)
