On mobile/smartfon (Android 10/Chrome/Huawei Mate 20 Lite) on album with photo proof functionality when I click on black check icon it change to green icon so it works ok but when I click again to green icon because I want to uncheck photo icon is not changing to black.
Similar situation is with comment icon on mobile. When I completely delete comment on mobile/smartfon and click save changes icon, green comment icon is not changing from green to black.
I believe that is the hover state that is activated on mobile. If you will click away, on another photo comment/checkmark, it will change color as it should.
What I think we could do is to distinguish hover state of inactive element, and active element.
Add such custom CSS to see the difference. I will also add it to next update:
Kind regards,
Arek
hover
state that is activated on mobile. If you will click away, on another photo comment/checkmark, it will change color as it should.What I think we could do is to distinguish hover state of inactive element, and active element.
Add such custom CSS to see the difference. I will also add it to next update: With kind regards.
Thank you very much for quick help
Maybe you are right is hover but ordinary user do not now that and could click again and again when see the same icon color.
Most important is that it work now like a charm :-)
Kind regards,
Arek
It will be added to the next update as well.
