I have found nice plugin for sort tags https://pl.wordpress.org/plugins/simple-taxonomy-ordering/ but there is no tab with images tags on Rife Theme Albums folder. Is it possible to add tags tab with all images tags to Albums folder. Then I could sort all albums images tags like my Client wants?
Are we talking about tags in the single album? If yes, then it is not possible.
I have just checked that tags added in each photo are sorted in an alphabet order -> rife\advance\utilities\cpt.php line 1573 I don't see any way for you to sort them, as they only appear in one album and are not avaible anywhere else, so no script can act on them beforehand.
Sorry if I misled you, as I was sure we were talking about Albums list, but now I see you have renamed single album to "portfolio".
No, we are talking about tags in all Albums. Of course Portfolio is most imortant album right now, but when I could sort tags on all albums it will have impact to Portfolio album too.
Is it passible to add tab with images Tags to Albums folder or sort all images albums Tags in the other way but like my Client wants?
I have found solution. On file cpt.php line 1574 I have changed asort($filters); to asort($age); and then tags on site https://skrzynecka5.js-metals.pl/i/portfolio/ are sorted in the same order like photos order on album Portfolio. Thank you very much for guide :-)
Does this $age variable stand for something? If not, you can as well remove this line totally from the file: asort($filters); and it will have the same effect:-)
Most important is that this is what you were looking for!
This is not the theme thing. You will need some plugin for this https://www.google.com/q=wordpress+reorder+tags+order
I don't have any recommendation.
Ok, I will search so on the internet :-)
Kind regards,
Arek
Kind regars,
Arek
Kind regards,
Arek
Kind regards,
Arek
Interesting solution.
Does this
$age
variable stand for something? If not, you can as well remove this line totally from the file:asort($filters);
Thank you for the tip : )
Kind regards,
Arek
