I'm a bit stuck on the mobile menu I see on the phone, not sure what I'm doing wrong here...
Thought I should be in the Header variants, made the changes on the Mobile section, but looks like it should be fine, but the site colours not showing up correctly..
Site is www.bethbarkerdesigns.com.
So sorry about this, been over the documentation but can't find any clarity :-)
Thanks so much, hoping this is a quick and obvious one. I've already changed the page settings to Light and Dark headings respectively...
If you are looking to change the background color for the mobile menu, then in your case go to:
Customizing → Header settings → Variant dark - Override normal settings → Mobile menu : Background color.
Best, would be to set black background probably.
