Apollo 13 Frameworks Extensions plugin is causing issues by not displaying crucial content on my website. When activated, custom header and footer templates/ sections created in Elementor Pro disappear. Header and Footer are enabled in Theme Customization. Also, published pages and posts do not display. (I type in slug/ permalink to published pages/ posts but it only reloads the front static page. When plugin is deactivated, page/ content displays as it should.) Please advise.
It sounds like some different conflict, but hard to say what could it be.
Could you link to pages where these issues are happening?
Here is a link to front static page (Coming Soon page), as well as a published test post page for Blog. Header (menu) and Footer are not showing on front page when Framework Extensions plugin activated. Test post redirects to static front page.
https://www.renderyourstory.com/
https://www.renderyourstory.com/test-post1
I tested again with de-activating the Frameworks Extensions plugin, and both pages appear as they should. Re-activating the plugin produces the problem.
Please advise.
I suspect that you have an active maintenance mode. Please disable it in the customizer, as explained here https://rifetheme.com/help/docs/customizing-the-theme/page-settings/maintenance-mode-page/
