Missing png files
edited August 2020 in PhotoProof Posts: 115
With Inspect mode (F12 in Google Chrome) see missing pf1.png and pf1_white.png. Where can download this files?
I think it's left over from the demo theme because there are some more png files missing.
GET /wp-content/uploads/2017/07/pf1_HDR_white.png HTTP/1.1
GET /wp-content/uploads/2017/07/pf1_white.png HTTP/1.1
GET /wp-content/uploads/2017/07/pf1.png HTTP/1.1
Post edited by robi052 on
    I suspect that are some links photoproof logo.
    Please share a link to your website, and I will check where they are referenced on your website.
    These are logo images set for the sticky header variant. Please go to Appearance → Customize → Header Settings → Sticky header – Override normal settings.
    You will have to edit 2 option there:
    1. Logo : Image
    2. Logo : Image for HIGH DPI screen
    and either remove an existing selection or set some image and then remove it.
    Save changes after you are done.
    Thanks. I select images. See tomorrow if is now ok. Thanks
    1920 x 1080 - 936K
    If you don't plan to use stikcy version of logo, you can remove it.
    These 404 errors was glitch after demo import. After reset of these setttings you are fine :-)
    Thanks. For now I leaving. How I see now all working fine 😁
