When I download the Rife Pro on my Mac, I see the folder labeled Rife and all its contents but the instructions refer to using a zip file to move and install. Should I also be looking for a zip files or is it automatically unpacked? If auto unpacked, how do I install the Rife Pro theme folder into word press. Thanks. Dave
I suspect that your system has something that unpacks the downloaded zip file.
When you purchase or click the link in the license code e-mail, you are downloading a ZIP file.
What you can do is either disable this feature in your system, or just pack the "rife" directory into a ZIP file with some software, and upload such file into your WordPress.
