Error message
in PhotoProof Posts: 125
On password protected page see this error message
"Warning: Constant A13FRAMEWORK_CUSTOM_PASSWORD_PROTECTED already defined in /home/USERNAME/public_html/wp-content/themes/photoproof/password-template.php on line 18"
    edited April 2021 Posts: 10,970
    Hey there:-)
    Did it appear after update 2.4.12 ?
    Please make such change in code, just to be safe in case somehow password template is included two times.
    Please edit a file photoproff\password-template.php ~line 18
    change :
    define('A13FRAMEWORK_CUSTOM_PASSWORD_PROTECTED', true );
    to:
    	if( !defined( 'A13FRAMEWORK_CUSTOM_PASSWORD_PROTECTED' ) ){
    Same error after update to latest version. I’ve seen this for a while now, but I didn’t get to report it. Ićm think after patch now is ok
    OK, thanks for the report. I will add the same fix for the next update.
    Thanks.... and if you find userul,update lightgallery 😁
