Hi Guys
First a simple question, if i have used 1 page and renamed it, can i then ad this page to the menu as a duplicate and then edit it, without editing the other similar page at the same time, it seems like when i ad a duplicate page, the pages are linked, so if i edit one page, the edit goes for the other page as well.
1. Shop page:
So this might be a bit tricky, i want to ad a different/simple shop page as just the usual woocomerce page, and i like the overall look of the page - album - gallery - 3 coloumns, which i already added to portry my artwork
https://artbyolivernielsen.dk/album/kunstvaerker/I want to ad this as a shopping/product page (have to figure out the ad to cart - check out thing later on), made a quick example in photoshop so you guys could see what i mean, see screenshot, is this possible?
I had such situations sometimes and I didn't even notice that is redirecting me ;-)
In which way have you created a copy of the first page?
So you have to use a single album that you have created and named as a shop page and link in the menu(if you want).
Rest of the shop you have to setup normally, and create products in traditional way.
After you are done with the whole setup, in each image of the album you can link to existing product, and this will create add to cart button over each photo that is linked to real product.
Look for the option "Product this image represents" while editing each image in the album https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/album-media/
Hope that helps :-)
"In which way have you created a copy of the first page?"
I just ad the page i have already made for the menu under appereanse - menu, maybe i´m just doing something wrong.
For the shop page question: So the only option to get this, is by editing a page through elementor and adding a normal gallery? It´s just because i like the overall look the Coloumn 3 album/page gives, so would be awesome if i somehow could use this for it.
You have to create physical copy of the page to have 2 separate pages.
You can do it using plugin like https://pl.wordpress.org/plugins/duplicate-post/
You can also do it in native view of the album, but your idea is much more flexible then mine. Adding a gallery to Elementor is great idea. Bra
just so i´m sure i´m not setting something up, that sn´t theme supported and makes conflicts etc
Our theme is tested and made to support WooCommerce.
Best would be to setup shop page with their wizard https://docs.woocommerce.com/document/woocommerce-setup-wizard/
By default shop page in our theme will look similar to this https://rifetheme.com/photoproof-8/shop/
or this https://rifetheme.com/fatmoon-victoria/shop/
You can customize few aspects of it in the customizer https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/shop-settings/
You can also add widgets to the sidebar in the shop sidebar https://rifetheme.com/apollo13-framework/docs/basic-setup/widgets-sidebars/
Shop page is mostly controlled by the combination of the theme and WooCommerce, so you can not edit it with Elementor. It is one of a few special types of pages, that are prebuild, like blog page, albums list, etc.
What you can do, is to use Elementor widgets and WooCommerce shortcodes to create customized page, that you will treat as your shop page(and link it in the menu). From there customers can click into specific products.
However, this solution depends on complexity of your offer in the shop, and might not be scalable for a large shop.
WooCommerce shortcodes https://docs.woocommerce.com/document/woocommerce-shortcodes/
see the difference?
Album: https://artbyolivernielsen.dk/album/kunstvaerker/
Shop: https://artbyolivernielsen.dk/shop/
Any idea why this is? it´s super important for me as an artist that my images is totally clear both on product catalouge page and single product page.
see screenie
Sure, you can set it in the title bar settings for the shop. Just be sure to reduce the opacity for the background color for the title bar, to see the image behind the color.
Appearance → Customize → Shop Settings → Products list – title bar
This place is called a subtitle, however, for shop there is no option to add a subtitle.
If you need you can use below code to have subtitle.
Best would be for you to use a child theme for the theme, and in functions.php file in the child theme, add such a code Just please swap the
My text
part to your text in the above code.About using the child theme https://rifetheme.com/apollo13-framework/docs/installation-updating/installing-child-theme/
Not sure this is something you guys can answer as well, but i have to make some T&C´s - privacy policy etc pages. What would you guys recommend for these pages, not sure they have to be as subpages under shop in the main menu, the could be in a footer on the shop page, or just linking to the pages on the cart page.
What would be best practise here? If this isn´t covered by your support i totally understand
Once you have them you can link them in footer widget for exapmle.
I wouldn't add them to the main menu.
In WooCommerce settings, there is an option to select your "terms" page, and it will link it in proper places in the shop. WooCommerce → Settings → Advanced → Terms and conditions .
If you want to adjust size of images in the shop, increase width in Customizing → WooCommerce → Product Images →Thumbnail width.
Next, you will have to regenerate thumbnails in WooCommerce → Status → Regenerate shop thumbnails
Hope that helps.
Tried to make my images better on the shop page, however i can´t seem to figure it out, so must get some help for this somehow, pretty funny i can´t do this as i´m an digital artist, go figure aye
1. I want to add a shopping cart icon, i have looked under appeareance - customizing - woocommerce, but can´t seem to find it, do you know how i can get it displayed, and if possible, i only want it displayed on the "shop page"
you will have to add some widget to the Basket sidebar https://rifetheme.com/apollo13-framework/docs/basic-setup/widgets-sidebars/
Not possible, and not advised as well.
Regarding the images, i appreciate you will take a look and not that i wont give you the log in etc, but spending time creating a new admin etc etc is a bit much to me, and i should be able to figure this out myself, appreciate the support though.
