York Theme - Site title and tagline not showing
in Rife Posts: 12
After importing York theme, in the frontpage the site title and tagline are not showing. Instead, the album title "Home Page Album" is showing.
My website: www.olilabs.com
I set up the site title and tagline in both Setting>General and Customize>Site Identity, and they are both the same (and correct).
I wonder if this has anything to do with front page being set to album instead of page.
How can I fix this problem?
Thankfully,
J.T. Oliveira
    joaotales said: I wonder if this has anything to do with front page being set to album instead of page.
    Yes, in some way it is connected.
    The best solution to this, when you are using the album as the front page, is to install the Yoast Seo plugin for example, and there override page title and other settings.
    https://wordpress.org/plugins/wordpress-seo/
