You can switch to default thumbnails in Customizing → Shop(WooCommerce) settings → Single product → Theme thumbnails → Disable. It will remove this space.
By the way, how did you make , that it doesn't display any thumbnail near the main product photo, even when there is only one photo. In my case it looks like this in such case:
It seems WooCoomerce updates old products with a single thumbnail while you enter edit mode. I have just added styles for such a scenario. Thanks for pointing this out!
I think the first way to do it is to change background color in Customizing → General settings → Content .
It will change the color of the content across the website.
Please let me know is it solution that fits you.
Please add such custom CSS to make desired changes: With kind regards.
I am not sure what it represents.
https://www.driven-f1.com/checkout-2/
https://www.driven-f1.com/cart-2/
For the cart and for the checkout: Hope that helps.
https://www.driven-f1.com/my-account-2/
For the checkout:
For the my-account it seems it colides with CSS I gave you previous time for the checkout.
So please remove this CSS: and instead add this CSS:
Hope that helps.
https://www.driven-f1.com/product/logo-collection/
