responsive issue
in FatMoon Posts: 10
Hi, for the two columns layout i have a picture on the left and text on the right. on mobile i just can't figure it out how to make the picture visible because is hidden. i've tried to untick visible on device with no luck. Thanks
    Could you share more details?
    Like a link to the page where it happens, and some screen shot, what is missing?
    Of course, https://tangoforyou.co.uk/group-classes or https://tangoforyou.co.uk/private-classes.
    As you see on desktop mode i added images and text, on mobile i have just the text visible and i can't find a way to make the images visible. I want to have image and text bellow but the image area dissapears. I've unchecked the "hide on mobile" from responsive but still no visible. If you send me an email i can reply back with my login credentials
    As these images are used as background images, they(containers) will collapse when nothing is inside.
    You will have to either add those images as normal "content images" or set some height for mobile view, for this container.
    Those containers are currently visible, but they have 1px of height.
    Solved, thank you
