Change Livicon
Hello, can you please explain what I'm supposed to do here? The instructions say "Please select "replace_me" text and hit "Add LivIcon" button" but there's no "replace_me" text. Clearly this is custom styled. How do I change the livicon but keep the same style?
thanks.
    You can remove the current code and just click on the Add LivIcon button.
    You can customize any icon directly in the LivIcon editor.
    With regards,
    Lead Graphic Designer
