Hi, can i have a recorsive album-subcategores filters? I'd like to navigate into ALL ALBUM SUB CATEGORIES... in my case the filter shows only the Main Category but not the subs. Can u help me? Tnx a lot in advance
It is hardcoded in the Apollo13 Framework Extensions plugin, so it is not safe to change it in the code. It can also mess up the visibility of your albums.
Only one level of categories is displayed. If you enter into the parent category it will again show children categories.
Try opening the link to your category, and you will see there your subcategories.
In your case it would be:
https://www.domenicosolimeno.com/genre/atlante/
https://www.domenicosolimeno.com/genre/categorie/
This is not changeable.
