Square payment gateway on Woo frozen
in FatMoon Posts: 124
The square payment gateway on checkout page in Woocommerce is apparently frozen. If you try to type in your credit card or any other detail it simply won't allow it. Any suggestions?
I've currently enabled Stripe to take payments.
https://Sensibleedibles.com
    I can see that your page is throwing JavaScript errors, and that is probably why you have issues with this plugin
    https://www.sensibleedibles.com/checkout
    Not sure why, but it would be great to test if some plugin doesn't make problems, maybe some optimization plugin?image
    794 x 111 - 8K
    Yes, apparently your right. The culprit is SiteGround optimizer plugin, specifically turning on Combine JavaScript Files and/or Defer Render-Blocking JavaScript will cause this problem. SG support suggest reaching out to Woo to find exact script affected and adding it to exclusion list.
    Using JavaScript optimizers is not an easy task in WordPress, where so many plugins and the theme, ads their scripts. It is very tricky, in my experience, to do it right, so it wouldn't create more problems than it solves :-)
