Backend Albums
i'm Attaching an album BackEnd screenshot. As u can see i've 1 very big bos for each photo. I remember that before in one box i found all the images of the album.
What happend?
Tnx in advance
    Hard to say, but I expect you are having some JavaScript error.
    Do you see anything in the console log?
    What u mean about CONSOLE LOG?
    If you press f12 in the browser you will see a console for Javascript and other debug tools.
    However, maybe better if I will take a look.
    Thanks for the data.
    I wasn't aware that this happens in the block editor(Guteneberg) as I only use classic editor.
    Quick solution: If you will resize the browser window it will fix itself and look good.
    Anyway, I will have to search for the code solution, to make it look good in the block editor admin as well.
    Thanks for your help
    What u mean about resizing the browser window? What i've to do?
    When you load the page for editing the album in your browser, minimize or resize the browser window. Like you are changing the size of other windows on your computer.
    I have the exact same issue as user "lightwords". The images of the gallery are way too big - same as on screenshot at the beginning.
    Thanks for the feedback. It will be fixed in the next version, as I wasn't aware of this issue in the Gutenberg editor.
