I dont know, how I can explain ... please look at the page www.thomas-gaese.de and see the text on the top and the bottom if you touch the images. The text change during the mouseover.
In what browser? Mobile(iphone, ipad) safari? I just checked your site on desktop computer and it works as it should. In touch devices after closing there may be still focus on this handle, and that is why it stays red. When you click to other element it should loose focus and get to default color.
Hi, its the normal Safari, no mobile. I find out, that the problem depends on the smaller browser. The text change only if I hover the items on the bottom (or the big one in the middle), it means only if I touch pictures with a part out of the window.
Probably your logo takes to much space(too wide), and menu is designed that way to have always height of logo, and it is always single row, up until it goes to 'mobile' menu. So on small screen it can collapse in some not good way.
I don't see anything strange.
In What browser did you saw issue? Have you checked other browsers?
Try using this custom CSS With regards.
