Hi! CROP is a good things but how i can do that? Can i have a Parallax or a "fit scroll" like original without other addons? Other: why the To Top arrow is expired? Now i see a rectangle instead the arrow (not anywhere... on my mobile and on site it is a rectangle! but in backend is correct... now!)
lightwords said: Other: why the To Top arrow is expired? Now i see a rectangle instead the arrow (not anywhere... on my mobile and on site it is a rectangle! but in backend is correct... now!)
Can you share what do you mean on a screenshot?
lightwords said: Can i have a Parallax or a "fit scroll" like original without other addons?
Yes :-) Add an album with our Elementor widgets or by shortcodes
Hi, i've already installed thr Widgets and by those i' create a page domenicosolimeno/Elem but, like the attachments, on mobile it is very different! I'd like to see the album like "normal" setting. For Parallax i can't find nothing. Waiting ur answer i send my br
Sound like some cache issue, because I have viewed your website under https://www.domenicosolimeno.com/ and the scroller is working fine both on mobile and desktop. Please check the private mode as well for this issue.
I'll try to deactivate all cache's plugins... but until now the problem is still on! Other problem is the different view of scroller album via elementor and via "default" like in attach files. The Bad screen shows the page domenicosolimeno/Elem ... the album is the same... why is different? The album is not fit and the fonts are very big...
Hi, the view is bad! I've used the Elementor's plugins but the result is different than the DEFAULT view! Normally the album fit the header either on desktop or on mobile but with plugins, like the screenshots, on mobile i see a "smaller" album... tnx in advance
Hi, i tried again it but it doesn't work! A good result can have using a spacer but it doesn't work good on my second monitor.... the scroller overlap the header and the album's images are bigger than the "original album view".
Screenshots In HeadOK the texts on the bottom (title) are lose but the header is clear. In the HeadKO the title is ok but the Header is overlapped by scroller.
Hi, i'm trying to use the widget... my problem is to fit the hight of screen! The album (the same that's show in home page actually, is higher in the widget so i can't scroll it usefully with mouse's wheel.... i'm extending the section and i'm using the "Stretch the slider to the window height" feauture.
Yes, I have tested it, and it seems that it is not possible with the widget, as it can not take into calculation the height of the header when stretching the scroller.
You either would have to use some proportion of the scroller instead of streratching to full height OR use auto semi-transparent header for the homepage only, so it would not cover your images to much.
Yes, we have made widgets for the Elementor to insert albums https://rifetheme.com/apollo13-framework/docs/content-management/elementor-widgets/
However, they for inserting them as a "gallery". Not sure it that is what you want.
You can also use the "Theme post list" to insert categories of albums.
You add an album as a gallery/slider/scroller in one section in another you can add a post list.
We are doing something like this here https://rifetheme.com/cropps/
or here https://rifetheme.com/lander/ - there is a post list and works list on the same page.
https://rifetheme.com/help/docs/content-management/elementor-widgets/
https://rifetheme.com/help/docs/content-management/shortcodes/
Could you check in private mode of the browser do you see the same issue?
Is the view in the Elementor preview is good or bad?
Have you tried viewing your website in the private mode of the browser?
Do those issues happen then?
the view is bad!
tnx in advance
Please see a screen shot
Screenshots
OR
