Hi there,
I wonder if you can assist me how to put the breadcrumbs with Yoast SEO on the position as per attached image. It's on the top left side of each post content.
I have put code snippet to the theme file editor "single.php" but its default position is at the bottom of each post.
https://asiatopdmc.com/event-venue-sourcing-in-vietnam/ Thanks and regards,
Phuong
I can not see your breadcrumbs. Are they still there?
Where exactly you inserted the snippet?
Hi have found the right place to put the snippet-:). and it works.
Thanks a lots for your help.
Kind regards,
Phiuong
