Menu in two columns.
in Rife Posts: 9
I have the Rife theme installed, and I would like to get a two-column menu with headings on it (as done in the Rebro theme, I attach a screenshot). How could I do this?
  • H,
    I believe this documentation thread will help you out https://rifetheme.com/help/docs/basic-setup/menus/using-mega-menu/
    Support, The
    Dear Surgeonito, this really helped, thank you so much!
    Now to get the menu of my dreams, I need to increase its width a little on the desktop version (I only use two columns, but the menu has items that are about 20-22 characters long and they don't fit in the standard column width). So I need to increase the overall width of the menu in case of using two columns, can you help me with this setting as well?)
    2880 x 1542 - 2M
