Outdated copies of some WooCommerce template files
in Rife Posts: 69
Hi there,
I just updated my website to the latest versions of the Apollo13 Framework Extensions (v1.9.3) and Rife Elementor Extensions & Templates (v1.2.1), and I got the following system alert:
rife/woocommerce/archive-product.php version 3.4.0 is out of date. The core version is 8.6.0,
rife/woocommerce/loop/loop-start.php
I have WP v6.4.4 installed. I did not updated to the latest one since I'm not sure of compatibility with Rife.
I would appreciate the team's help with this.
Thank you!
    What is your WooCommerce version?
    Where are you getting this error? Can you provide any screenshot?
    Support, The
    Ok, I think I know what is the issue here.
    One more question - are you facing any issues with displaying the products' lists?
    Support, The
    Hello Surgeonito,
    My WooCommerce version is 8.8.2. I don't see any issues with the product lists or specific products on the front end or back end, but I haven't looked deeply yet.
    I hope this helps.
    Thank you.
    PS. I also need to update the WooCommerce database, which I haven't done yet. Wanted to see first if the woocommerce folder in the Rife theme needs to be updated.
    So - you should not be worried about this notification. This is just a version comparison - the code will not be changed, but the version tag will be.
    I have tested our theme with latest wordpress and latest wooccemmerce.
    So pls go ahead and update whatever you need.
    Support, The
    Thank you for looking into that for me!
    Hello there
    I have a similar issue with following message
    Your theme (Rife Pro) contains outdated copies of some WooCommerce template files. These files may need updating to ensure they are compatible with the current version of WooCommerce. Suggestions to fix this:
    Update your theme to the latest version. If no update is available contact your theme author asking about compatibility with the current WooCommerce version.
    If you copied over a template file to change something, then you will need to copy the new version of the template and apply your changes again.
    Theme is up-to-date and WP is at latest version as well as WooCommerce.. Database also updated.. message remains..
    Thanks for helping here
    Pascal
    Hi Flyart - have you update the theme? The latest version has this notification.
    Support, The
    Yes, the theme is updated to 2.4.20 but I still get the message
    Thanks for the info.. but this version doesn't show to be updated im my theme or update panel.. how can I force install this update?
