Website down
edited August 2024 in PhotoProof Posts: 125
After upgrade Apollo13 Framework Extensions today frontpage dont work. Try disable all plugins, downgrade PHP version, create new home album, but the problem is still present. I attach debug.log, front page and screenshoots of plugins.
PHP Version 8.3.10
Affected URL: https://www.robertobilic.com/
Post edited by robi052 on
    from logs you provide I assume there something wrong with the WPML plugin that is causing the website to crash.
    Support, The
    I tried deactivate WPForms Multilingual, WPML Multilingual CMS, WPML SEO, WPML String Translation but problem is not resolved
    Have you modified the theme files manually? I can see you have Photoproof and its clone installed and activated.
    Support, The
    Child theme. Now try activate Parent theme without modifications, but no changes
    Try remove all and restore backup. Website working. After update Apollo13 framework stop working
    Restore backup with Apollo13 Framework Extensions version 1.9.4 and all work fine
    1.9.8 has been released with a fix.
    Support, The
    Version 1.9.8 work fine... Thanks @Surgeonito :smile:
