page not loading then critical error
my shop page wouldn't load. I contacted wordpress support and they found the fatal error codes. After I got out of the chat my entire site isn't loading on my desktop although it is loading no my phone. Please understand I know nothing about website coding. any help would be greatly appreciated.
url https://gabeleonardart.com/
  • WordPress version 6.6.1
    Active theme: Rife Pro (version 2.4.14.1)
    Current plugin: (version )
    PHP version 8.1.29
  • Fatal error: Uncaught Error: Attempt to modify property "response" on bool in /srv/htdocs/wp-content/themes/rife/advance/inc/theme-update-checker.php:187
    Hi.
    I went through your website and it loads OK.
    What is exact URL that you want me to check?
    Support, The
  • all I'm getting is a grey screen on desktop browsers. nothing loads except on my phone using firefox at the moment
  • wordpress support went through and found fatal error codes and said it had something to do with the theme. I can provide those codes if it helps
    https://gtmetrix.com/reports/gabeleonardart.com/df7ETk0M/ - this is a gtmetrix scan. Website is perfectly available publically.
    If you have a error log - pls send me it. I will take a look
    Support, The
  • I had to restore my site to a previous date. that worked until today
    when I attempt to log into my admin it gives me a critical error message. when I try to go to my site I get a blank grey screen and nothing I do changes that
    except using a different browser, which loads my site just fine until I try to login to admin and then the same thing happens on the that browser too
    wordpress support sent me a string of error codes before I restored my site. I'll send those over
