Add photo credits on RIFE Pro theme
Hello
We have several fields on our media library allowing captions and also photo credits to be added. However these do not show up on hovering or clicking on any images in the theme. Is there something I can easily do to show this field when hovering or clicking on an image?
Many thanks
Andy
  • If you are talking about the Albums: edit the album, scroll down to the 'Album Details' section, select 'Album media' from the left menu and you have there two options:
    1. Show texts - without hover
    2. Show texts - on hover
    you can enable/disable them as you wish
    Support, The
  • hi Surgeonito
    We have the show text on enabled. We are asking about something different. Each image has several fields within which we can add information. i.e.: Captions, Alt Text and Photo Credits.
    When we look at an image only the title and description show. Can the theme enable the other fields to also show? Ideally this information would show in this location marked red in the attached image.
    Thank you
    2050 x 1276 - 3M
  • Check this option in album edit panel.
    1271 x 760 - 71K
    Support, The
  • Hi, Thanks for your response. That function is to switch on the title and description. we would like to enable the caption field to be enabled and to show under the description.
    Is this possible?
    Thank you
  • If you take a look at https://rifetheme.com/fully/album/fullscreen2/ - you have an example of album that presents the image caption.
    Have you checked it?
    Support, The
  • That site is only showing the Title and Description of the image. We also have those showing but want to additionally show the ALT text or Caption. If you look at the mark up image, we want to show these fields on the website image, - at the moment only the Title and Description show. Can we have some CSS code that allows us to add the fields (ideally just the Caption), to show on the image. Please help
    2751 x 1489 - 2M
  • Hi, can we please have some support for this feature?
    We are using the RIFE pro Child theme
    Thank you
  • Hi,
    at this moment this is not possible. You can display Title and Description only in this area.
    I will put this on our development roadmap though.
    Support, The
  • Thanks for letting us know.
