Discussions
Categories
Home
Rife
Add search bar to the top header.
vang3lov
June 2025
in
Rife
how can I add search bar on any of following positions in the attachment?
Surgeonito
June 2025
At this point it's not possible.
You would have to modify the code with use of Child Theme.
Are you using any plugin for a search bar? Or maybe you want to use standard one?
Support, The
vang3lov
June 2025
I Use the standard one. May be i can put it under the main menu with widget ?
Surgeonito
June 2025
Go to 'Customizing ▸ Widgets ▸Header(vertical) default widget area' and place there a 'Search' widget.
Support, The
vang3lov
June 2025
Thank you very much! Work very good!
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
117
OneLander
333
PhotoProof
617
Rife
40
Agency
130
Starter
887
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
June 2025
vang3lov
June 2025
Surgeonito
Discussions
Categories
Sign In
