bbPress forums - adjusting font size on mobile
in Rife Posts: 10
I recently added bbPress forums to one of my sites - but the font size on mobile is extremely small. How could I increase the size?
    can you share the URL?
    Support, The
    Would be better if you could provide the exact URL of the page that presents the issue you're talking about.
    And maybe a screenshot with marked element that is affected?
    Support, The
    I did - just above. https://weddingplanningheadquarters.com/forums/
    I am using Rife Pro and was just looking for the ability to increase the font on mobile. I was assuming that there would be somewhere in adjusting appearance that would affect the display size.
    OK, so BbPress has it's own styles and you should address these questions to BbPress support.
    I checked the URL you provided, but there are many elements that you would want to increase the font size for.
    So you can overwrite this CSS rule to increase font-size from 11 to 14 pixels:
    #bbpress-forums .bbp-forums-list .bbp-forum{
    font-size: 14px;
    1854 x 1084 - 199K
    Support, The
