Hi, I'm wondering how to make my blog just like your Demo version at ThemeForest:
1 - When you visit my blog you'll see those little light boxes, but I want the full last post just like you have in Demo version.
http://www.anamatias.net/blog/2 - If you see one of those posts, you'll find a photo bigger than the white background, so I'm asking how to remove it (just in blog section - because works on portfolio).
Thank you!
1. Use Blog post Detail - Add Image and videos to add featured images and videos from here http://apollo13.eu/docs/airlock/#!/adding_new_posts
2. That photo you added is in text section - there you have to control it by yourself what you insert. So just choose smaller version of image there.
First of all, I used the 'Blog post Detail' and nothing has changed, I still have those little empty boxes on my blog page (http://www.anamatias.net/blog/). I also tried the Airlock > Advance > TimThumb 'Yes', but with no luck.
When I asked you about that white background on the posts, I was waiting for a solution because I thought we (buyers of your themes) could have our pictures with any size we want, but looks I'll have to find out something else by myself.
I have to say it, after being very happy with this Airlock theme, now I feel kinda disappointed with all the blog section. I just wanted a simple 'photoblog' with photos from my Flickr account.
I've solved the problem with the white background on posts, just removing it. Now, I hope you can help me with the blog page once I can't figure out why the thumbs are not showing up.
Thanks.
More serious: I don't know it you wish to widen this white area(there was some topic about it), or just make pictures always fit there. For second use this custom CSS And that is what you got:-)
I still have the same problem. I'm so tired to try to figure it out but I don't understand what's happening.
Everything it's OK with the blog post (http://www.anamatias.net/2012/12/test/) - but if you go back to blog (http://www.anamatias.net/blog/) you won't see any thumb picture.
In the 'Blog post Detail' section I use the 'Upload Image' but nothing happens (works with the portfolio thumbs, why isn't working with blog?)
Please, help me with this.
Thanks.
Anyway, send me temporary access to your WP so I could check there what is going on? Send it here on forum via private message .
About setting images in blog:
If you have empty first image set, then image wont show up on blog post list. Remove empty one- check screen shot
