Slight Problem!!
edited December 2012 in Hypershot Posts: 5
Hi
I am having a slight problem with this theme. It looks okay in all browsers except Firefox. When using Firefox there is no navigation menu. Could you please advise me what could be wrong.
My site is http://www.wildshots.org
Cheers.
    I see some plugin is causing JavaScript errors. Try switching off each plugin and check when it starts to work. Then report what plugin it was, and I will take look on my installation.
    Hi
    Thanks found it and deleted the plugin. It was an old plugin that should not have been active. OOooppps
