iPhone 4 main page problem
errerr
edited December 2012 in Spaceship Posts: 1
generally I found earlier topic here
http://support.apollo13.eu/discussion/comment/2252#Comment_2252
which helped me understand few problems - like floating footer ;)
So can i be calm as long as i'm viewing page on newest iOS?
Anyway I didnt found anything about my main problem.
While in Main Page the photo which suppose to navigate to some album are not displayed, only white frame aroud it is visible, while the photos in background are (more or less) fine.
Im attaching screenshots. Is it problem with old iOS, or is it made by some css code manipulation?
thanks
    Hello.
    Thanks for posting. I think this is issue of our theme. I will fix it soon, it is in queue of things to do. So please stay patient ;-)
    Update with many fixes and tweaks will be soon available on ThemeForest to download. You will get notification in your wordpress admin. This problem is solved in update as well.
    With regards and happy new year!
