Hi there,
Just purchased your Hypershot theme, and with great frustration, I am not able to upload your theme to WordPress...
When I upload the zipfile in the WP dashboard, it comes up with an error stating,
"The package could not be installed. The theme is missing the style.css stylesheet.
Theme install failed."
The funny thing is, is that the stylesheet is indeed there, but for whatever reason, there is no ".css" extension after the file.... and I can't manually add it to the end for what ever reason.
Am I missing something here? How is everyone else able to upload the theme? Any help would be appreciated!
Are you sure that you extracting ZIP file with theme from whole ZIP file you get from themeforest before trying to install?
Please try this guide from our documentation http://apollo13.eu/docs/hypershot/#!/installation_update
If you still wont be able to do it I will ask you for access data and help you do it, so please do frustrate any more :-)
With kindly regards.
I didnt realize the zip file contained two different themes. Was trying to upload the zipfile with both themes in there. haha
Maybe this plugin will help you http://wordpress.org/extend/plugins/wp-retina-2x/faq/
However Airlock used very old method for creating thumbnails so it may not work.
