You know tool firebug, or depending on browers you use, tool hidden under f12? It will help you locate every style. For that one wp-content/themes/airlock/common/css/style-light.css line 226
Yes I work with firebug. But it's hard to knew where to put the changes. I have activated the plugin "My Custom CSS". It seems to work well. Thanks for your fast support!
For that one
