I purchased the them last night, attempted to upload the them on wordpress but everytime I try it get a wordpress failure notice & it asks me to try again. I've uploaded several themes before. If you can help that would be great
Do you upload whole zip you got from themeforest, or just theme zip(airborn.zip) via wordpress ? If you have problem uploading via wordpress panel: 1. login to your FTP where you have installed WP, 2. go to /wp-content/themes 3. create folder airborn 4. upload there everything that is in airborn.zip 5. Now you should have airborn visible in your theme list in WP
Remebere airborn.zip is theme, NOT airborn-portfolio-business-wordpress-theme.zip
I have encountered another problem. I can't seem to change the background image or the fonts.
I have put the url for the custom background image, but when I save it doesn't show. Same with the fonts. Cufon is, but when I pick a different one, the fonts do not change
Please provide us some more info. Of which part you change BG image? Does it save your settings(you can see entered URL after reload of settings page)? Do you see any notifications in your WP admin? WP Version? Any link to your project?
Hope that helps!:-)
Thank you very much by the way, this is an excellent theme! very simple & easy to use, it's worth the money definitely!
WP Version?
