Mobile blog filter extends out of screen
edited January 2013 in Hypershot Posts: 39
Hi
In attached image you can se that in an iphone 4 the blog filter menu extends out of the screen. This happens only in vertical position (horizontal display is all visible). Maybe it could be change to display in the same way that an Album list filter displays (vertically).
How can this be solved?
http://www.proinsus.com
Gonzalo
