Overcrouded Screen in Mobiles
edited January 2013 in Hypershot Posts: 39
Hi
In my iphone the left and right arrows are on top of the images ( a little to big) and the icon numbers also fall on top of the image. The problem is that I have some albums with 25 images and then almos all of the screen is full of items that cover the images. Is it possible to make the numbers dissapear and make the arrows smaller.
Gonzalo
    If you wish to make changes only on small screens use this custom CSS
    @media only screen and (max-width: 650px) {
    /* Hide numbers */
    #slide-list {
    display: none !important;
    I messed for a bit with giving you CSS for resizing arrows, but this just ended up tricky and takes not nice side effects, so there wont be solution.
  • Air
    Thanks The code worked fine
    Could it be possible to aling arrows vertically on top or bottom?
    Gonzalo
    To push them to top you could use this
    html.touch .prev-parent, html.touch .next-parent {
    margin-top: 0;
    top: 0;
  • Air
    Yes it did.
