Add next Image or Video Button
edited December 2011 in Airlock Posts: 95
Hi i noticed when i want to upload, lets say 3 Pictures in the Portfolio under one Project, and expand the "Add next Image or Video" Button ( in Admin Backend ) and decide later to dont uses the expanded Add Image option it should be again possible to collaps it back.
    It is not used if left empty, so it only bother your eye, not theme :-)
    Yes its right but you know the summary of the well designed Details makes the Theme uniqe ;-)
    Yes :-) We will add remove option in near future. It is not so simple as it seems :-)
    great
