I can't work out how to change settings for single page blog posts in order to remove the side bar and change the background. It works for the full blog posts but not single posts.
For example:
This is correct:
http://www.simongreig.com/blog/ (no side bar and background image)
This is incorrect:
http://www.simongreig.com/beijing/ (no background and a side bar)
Hypershot 1.1.1
WP 3.5.1
No code mods
Thanks,
Simon
I can change it for individual posts. Where is the setting to change the default setting for new posts that I can permanently turn off the sidebar and set a background image?
Sidebar
There is no global setting to turn it off in every post, however you can do it for each post. Other option is to empty blog sidebar so it won't show up anywhere(blog, single post, search results, archive page and 404 error page)
Background
There is no such global setting. You can set global background for whole page in
Hypershot theme-> Appearance
. Individual background where made rather for "content" purpose.With regards.
I still think there is a small bug though. If you look at the single blog post page (http://www.simongreig.com/beijing/) you can see that it hasn't rendered the boxes as "flat" (they are rounded and have a very small shadow).
I have the following settings:
Blogs & Archives -> Blog Appearance -> Flat look side bar = ON
Blogs & Archives -> Blog Appearance -> Flat look blog items = ON
Blogs & Archives -> Archive/Search results Appearance -> Flat look side bar = ON
Blogs & Archives -> Archive/Search results Appearance -> Flat look blog items = ON
