Please I would like to know if it is possible the following: I want to use a single background album in bricks mode and when you press in each one of the album images, I do not want to watch the lightbox, I want to see the same single album but with the slideshow option.
Thanking you in advance for your attention,
Kind regards,
Maybe you just want albums list as bricks theme, and that albums open as sliders.
You should follow this http://apollo13.eu/docs/hypershot/#!/adding_album and this
http://apollo13.eu/docs/hypershot/#!/albums_menu
I want to use the single bricks theme for just one album not an albums list (all the images shown in each brick belongs to the same album) and open this single album (if you click in any image-brick of the album) as slider. Actually when you do this only opens a lightbox and I prefer the slideshow because of the autoplay buttom and the thumbnails, it is more attractive and easy to use.
Kind regards,
If you want to present all thumbnails from start, then when selecting slider them album, turn on thumbnails to be visible on page load(option Enable thumbnails list AND Show thumbnails/text/none on page load)like here http://themes.apollo13.eu/hypershot/album/patterns/
Thanking you in advance,
