Hi, I'm trying desperately to change the logo on hypershot for a text but the layout always gets messy when I change the logo image on Header.php for a hyperlink. Could you help me with that? =/ Thank you!
I'm just having some trouble with the Text logo. When I change the code the menu goes to the header top and doesn't stay aligned in the middle as it was with the image logo. Any thoughts on how could I solve this? Thank you!
But here it is: When I open a Full Width gallery (full width slider) is there any way for the description text to open automatically?
Text for logo
Go to
header.php
line ~164, find: change to and changeYOUR TEXT
to what you like.Next you will have to add some custom CSS to make it look better: Description
Go to your album, and enable option Show thumbnails/text/none on page load.
I prepared code that way it should be vertically aligned and tested it, so I have no idea why it isn't working for you.
That code worked like a charm. I would like to apply the same thing to my albums list page:
http://jamesautery.com/projects/
Where and how do I change that?
Best,
