Problem installing Hypershot update?
edited March 2013 in Hypershot Posts: 4
E aí?
Genius work on the theme. Thank you.
I am trying to install the current update and failing.
Have done the following steps:
Download the latest zip file for your theme.
Log into your WordPress site.
Go to Appearance > Themes.
Click the "Install Themes" tab.
Click the Upload link below the main page tabs.
Select the zip file with the new theme version to install.button I can see to
But at that point there is no option to:
>Select "Yes" from the "Upgrade existing theme?" option.
the only option I have is "install now"
and I get "destination folder already exists" ..." theme install failed"
I have wp 3.5.1 installed. Running OS x 10.6.8?
Also should I install the theme or the child theme?
Also how do I make the videos play in a smaller window, That is not full screen?
Obrigado
http://meiertavis.com/
Post edited by push on
    Ah theres a plugin to fix this..... no worries
    http://wordpress.org/extend/plugins/easy-theme-and-plugin-upgrades/
    IF you get a moment to help me with the size question
    Obrigado
    Good you solved update case.
    About video you can try this solution from our other theme http://support.apollo13.eu/discussion/comment/3773#Comment_3773
    My css editing is not so hot yet.
    I don't know where exactly to drop that code into.
    I guess the easiest way to describe what I am looking for is that the videos in the "showreel" player would play around the size of the "video grid" player.
    It may already be built in to the theme?
    here you have listed three options to do that:
    http://apollo13.eu/docs/hypershot/#!/modification_of_theme
    I advise doing it with plugin help.
    By the way if you wish your video to not hide below footer header use option Fit album( Lets you choose if you want to use full screen album, or should it be put between header and footer elements.)
    push said: I guess the easiest way to describe what I am looking for is that the videos in the "showreel" player would play around the size of the "video grid" player.
    Yes it is built in theme - use bricks theme:-) In slider theme you will not achieve such effect however you can experiment with code I gave you.
